[Qgis-user] TIN Interpolation from points (survey) with breaklines
Casoli-Risorsaterra casoli at risorsaterra.it
Mon Apr 2 13:21:10 PDT 2018
Thak you Teddy
I tried installing Openjump and Interpolate Points with breaklines using
the proper Sextante tool but even, if the triangulation was right
(respect to the breaklines), the quotes of the 2,5D polygons generated
by the tool were not right! Maybe I missed something?
Looking around for some tools useful for my purpuse, I found the
v.Triangle (1) Grass module that is no more contained in the Grass
Processing Tool in Qgis (or at least I couldn't find it!)
It's simply a "front-end" to the famous utility Triangle
<http://www.cs.cmu.edu/%7Equake/triangle.html> (2) of J.R. Shewchuk
...and It should be exactly what I need in Qgis.
Could I do something to support the (re)developping or new adding of
this processsing module?
Thanks in advance.
Riccardo
/_*Riccardo Casoli*_, Geologo(email:casoli at risorsaterra.it
<mailto:casoli at risorsaterra.it>; cell:3289026131)/
Studio Associato Risorsaterra
/di Massimo Barbonaglia, Riccardo Casoli,
Michele Colombo, Federico Cravello/
via Coda, 22/E - 13900 Biella Chiavazza
Tel e fax: 01523346
e-mail: info at risorsaterra.it <mailto:info at risorsaterra.it>
PEC: risorsaterra at professionistipec.it
<mailto:risorsaterra at professionistipec.it>
C.F. e P.Iva: IT02413380029
______
(1) https://grasswiki.osgeo.org/wiki/TIN_with_breaklines
(2) http://www.cs.cmu.edu/~quake/triangle.html
*Da:* Qgis-user-request <qgis-user-request at lists.osgeo.org>
*Data:* Venerdì, 30.03.2018 11:01 +0200
*A:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
*Oggetto:* Qgis-user Digest, Vol 145, Issue 62
> Message: 1
> Date: Wed, 28 Mar 2018 20:10:21 +0200
> From: teddy guerin<teddyguerin at yahoo.fr>
> To:"casoli at risorsaterra.it"  <casoli at risorsaterra.it>
> Cc:qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] TIN Interpolation from points (survey) with
> 	break	(interrupt or constraint) lines
> Message-ID:<21A57A6C-C608-4C42-8E50-BDDB4B0FF75F at yahoo.fr>
> Content-Type: text/plain; charset="utf-8"
> Hi,
> I seem that you use grass (module of qgis) for this action or openjump 😉.
> Regards
> Ted
> Envoyé de mon iPad
>> Le 28 mars 2018 à 19:23,"casoli at risorsaterra.it"  <casoli at risorsaterra.it>  a écrit :
>> Hi everybody
>> I have a PointSHP with Z field value that represents the survey on a step vineyard: points have been token along base and edge of steps to represent slope breaks.
>> In order to build a TIN (DEM) I created a line SHP and drew a series of lines linking  related  points (respecting morphological alignements).
>> Then I tried to build a triangulagion TIN (DEM) by "Interpolation TIN" tool using my points with their Z elevation field and my breaklinesline SHP to constrain triangulation inside each slope or step.
>> But the TIN obtained is a regular inclined surface that follows the general slope of the whole survey given by mean of z value of points: no steps no slopes.
>> Where I miss? What is the way to build a TIN from points with constrain lines?
>> I send an image that represents the points and breaklines on a orthophoto foreground and beside the same vector elements on the resulting TIN by interpolation.
>> Thanks in advance.
>> Riccardo Casoli, Geologo (email:casoli at risorsaterra.it; cell:3289026131)
>> di Barbonaglia, Casoli, Colombo, Cravello
>> Agricoltura, geologia, foreste
>> via Coda, 22/e
>> Tel e fax: 01523346
>> e-mail:info at risorsaterra.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180402/fe26c9e6/attachment.html>
