[Qgis-user] [QGIS-Developer] QGIS 3 Print Composer - Page Properties
Alexandre Neto senhor.neto at gmail.com
Tue Apr 3 02:56:29 PDT 2018
Nyall Dawson <nyall.dawson at gmail.com> escreveu no dia terça, 3/04/2018 às
05:16:
> On 3 April 2018 at 07:06, Carlo A. Bertelli (Charta s.r.l.)
> I've thought long on this. I'm reasonably convinced it's a short-term
> issue as people adjust there 2.x workflows to 3.0.
Although this is true, I still think it is not very intuitive for newcomers.
> There's two approaches I can see working to mitigate it:
> 1. Add a "pages panel", which allows you to pick from existing pages
> (e.g. via a drop-down combo box) and then set the properties for that
> page. It could also have the actions for adding new pages and deleting
> existing pages there too.
This would be the way I prefer, or include that same "widgetery" in the
layout properties. The "current" page could update based on the portion of
layout that is visible, as already happens for the grids panel.
> and/or
> 2. Add a "new layout wizard", which shows when you create a new print
> layout. This would prompt users to set the page size before the layout
> is actually created. It could potentially replace the existing layout
> manager approach to creating layouts from a template, e.g. by showing
> a nice list of available templates via thumbnail graphics.
I love the idea of having a list of available templates with some
thumbnails. But it won't fix the issue of not being trivial to see a pages
properties once te layout is created.
> Unfortunately both approaches aren't trivial, and would require some
> hours to implement.
"Small" crowdfunding? :)
> Nyall
> > c
> > On Mon, Apr 2, 2018 at 10:01 PM, Alessandro Pasotti <apasotti at gmail.com>
> > wrote:
> >> The reason for this change is that your can now have different settings
> >> for each page.
> >> The page size is not a property of the layout anymore but it's a
> property
> >> of the page.
> >> But I agree that the page properties might be better exposed.
> >> On Mon, Apr 2, 2018, 21:56 C Hamilton <adenaculture at gmail.com> wrote:
> >>> I was just going to ask what happened to the "Page Size" properties in
> >>> the QGIS 3 print composer, but I stumbled upon it accidentally by
> >>> right-mouse clicking on the page and selecting "Page Properties." This
> was
> >>> not easily found. In the QGIS 2 print compose it is a part of the
> layout. In
> >>> QGIS 3 I just lucked out.
> >>> Could the page properties be more obvious to find? At lease add them to
> >>> the Layout or Edit menus or put them back under the layout settings.
> >>> Thanks,
> >>> Calvin
> > Carlo A. Bertelli
> >    Charta servizi e sistemi per il territorio e la storia ambientale srl
> >           Dipendenze del palazzo Doria,
> >           vc. alla Chiesa della Maddalena 9/2 16124      Genova (Italy)
> >           tel./fax +39(0)10 2475439  +39 0108566195
> <+39%20010%20856%206195>  mobile:+39 393 1590711 <+39%20393%20159%200711>
> >    e-mail: bertelli at chartasrl.eu      http://www.chartasrl.eu
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/e7c15fb7/attachment.html>
