[Qgis-user] [QGIS-Developer] QGIS 3 Print Composer - Page Properties
Andreas Neumann a.neumann at carto.net
Mon Apr 2 23:43:06 PDT 2018
Hi Nyall,
I also think that the current situation where the page properties are
only exposed on right-click is not so ideal. From your two options you
list I would prefer option 1 with the separate "pages" panel. I don't
think that wizards are so effective - definitely not for experienced
users. I also don't like it when extra windows pop up. It would be nice
to get rid of the "layout manager" for the long term. Opening separate
windows is often confusing for people - these windows often hide below
other windows and sometimes they block QGIS while that other dialog
window is waiting for user interaction - not so ideal.
Can you estimate how much work option 1 (pages panel) would be? Could
this be included in an upcoming crowd funding campaign with print
composer improvements?
Thanks for your reply,
Andreas
On 2018-04-03 06:16, Nyall Dawson wrote:
> On 3 April 2018 at 07:06, Carlo A. Bertelli (Charta s.r.l.)
> <carlo.bertelli at gmail.com> wrote:
>> I suggest to provide the same interface as version 2 calling this "default
>> page size" and explaining that every page could get a different size,
>> right-clicking on the page. Most users make one-page maps and they would
>> never need this otherwise vital feature.
> I've thought long on this. I'm reasonably convinced it's a short-term
> issue as people adjust there 2.x workflows to 3.0.
> There's two approaches I can see working to mitigate it:
> 1. Add a "pages panel", which allows you to pick from existing pages
> (e.g. via a drop-down combo box) and then set the properties for that
> page. It could also have the actions for adding new pages and deleting
> existing pages there too.
> and/or
> 2. Add a "new layout wizard", which shows when you create a new print
> layout. This would prompt users to set the page size before the layout
> is actually created. It could potentially replace the existing layout
> manager approach to creating layouts from a template, e.g. by showing
> a nice list of available templates via thumbnail graphics.
> Unfortunately both approaches aren't trivial, and would require some
> hours to implement.
> Nyall
> c
> On Mon, Apr 2, 2018 at 10:01 PM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
> The reason for this change is that your can now have different settings
> for each page.
> The page size is not a property of the layout anymore but it's a property
> of the page.
> But I agree that the page properties might be better exposed.
> On Mon, Apr 2, 2018, 21:56 C Hamilton <adenaculture at gmail.com> wrote:
> I was just going to ask what happened to the "Page Size" properties in
> the QGIS 3 print composer, but I stumbled upon it accidentally by
> right-mouse clicking on the page and selecting "Page Properties." This was
> not easily found. In the QGIS 2 print compose it is a part of the layout. In
> QGIS 3 I just lucked out.
> Could the page properties be more obvious to find? At lease add them to
> the Layout or Edit menus or put them back under the layout settings.
> Thanks,
> Calvin
Carlo A. Bertelli
   Charta servizi e sistemi per il territorio e la storia ambientale srl
          Dipendenze del palazzo Doria,
          vc. alla Chiesa della Maddalena 9/2 16124      Genova (Italy)
          tel./fax +39(0)10 2475439  +39 0108566195  mobile:+39 393
1590711
   e-mail: bertelli at chartasrl.eu      http://www.chartasrl.eu
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/68586c03/attachment.html>
