[Qgis-user] True North
Springfield Harrison stellargps at gmail.com
Tue Apr 3 01:25:46 PDT 2018
Alexandre,
I believe that true north is actually a constant oriented towards the North
Pole, i e 90 degrees north latitude. Also where all meridians converge in
the northern hemisphere.
The other North orientations are magnetic north and grid North and these do
vary as you suggested.
I do need to use a UTM projection but need bearings to be in degrees true
north.
Thanks Alexandre...
Cheers . . . . .   Spring
Samsung Tab 4
On Apr 2, 2018 4:27 PM, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
> AFAIK, true bearing differs in time and location because of magnetic
> declination. So I don't think there is a such thing as a CRS with true
> bearings.
> Assuming you are working at regional level, find the magnetic declination
> for that region and remove it from your observations. Then draw the azimuth
> using the chosen CRS. I think 26910 will work just fine.
> If you are at a larger scale, then you may need to use different magnetic
> declination values for each observation.
> This may help:
> https://www.ngdc.noaa.gov/geomag/declination.shtml
> Best Regards,
> Alexandre Neto
> A seg, 2/04/2018, 23:54, Springfield Harrison <stellargps at gmail.com>
> escreveu:
>> Hello,
>> I am using CRS 26910, NAD83 / UTM zone 10N, and need to draw lines at
>> exact true bearings.  The Advanced Digitizing Tool seems to do this but
>> which CRS would I use to ensure that the bearing is True?
>> Thanks very much . . .
>> Cheers . . . . . Springfield Harrison
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/c56788f5/attachment.html>
