[Qgis-user] True North
Alexandre Neto senhor.neto at gmail.com
Tue Apr 3 02:11:31 PDT 2018
Ah sorry,
I got lost in translation. You are right, I was talking about the magnetic
north, not the geodetic one.
Meanwhile,  remembering that all UTM are Transverse Mercator, I don't think
there's a CRS that will solve you question.
I think you need to use some formula to convert the grid north measures to
true north according to the CRS, and the latitude and longitude of the
place.
Alexandre
A ter, 3/04/2018, 09:25, Springfield Harrison <stellargps at gmail.com>
escreveu:
> Alexandre,
> I believe that true north is actually a constant oriented towards the
> North Pole, i e 90 degrees north latitude. Also where all meridians
> converge in the northern hemisphere.
> The other North orientations are magnetic north and grid North and these
> do vary as you suggested.
> I do need to use a UTM projection but need bearings to be in degrees true
> north.
> Thanks Alexandre...
> Cheers . . . . .   Spring
> Samsung Tab 4
> On Apr 2, 2018 4:27 PM, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>> AFAIK, true bearing differs in time and location because of magnetic
>> declination. So I don't think there is a such thing as a CRS with true
>> bearings.
>> Assuming you are working at regional level, find the magnetic declination
>> for that region and remove it from your observations. Then draw the azimuth
>> using the chosen CRS. I think 26910 will work just fine.
>> If you are at a larger scale, then you may need to use different magnetic
>> declination values for each observation.
>> This may help:
>> https://www.ngdc.noaa.gov/geomag/declination.shtml
>> Best Regards,
>> Alexandre Neto
>> A seg, 2/04/2018, 23:54, Springfield Harrison <stellargps at gmail.com>
>> escreveu:
>>> Hello,
>>> I am using CRS 26910, NAD83 / UTM zone 10N, and need to draw lines at
>>> exact true bearings.  The Advanced Digitizing Tool seems to do this but
>>> which CRS would I use to ensure that the bearing is True?
>>> Thanks very much . . .
>>> Cheers . . . . . Springfield Harrison
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/d5979ee5/attachment.html>
