[Qgis-user] True North
Alexandre Neto senhor.neto at gmail.com
Tue Apr 3 02:15:08 PDT 2018
Maybe something like this :
https://gis.stackexchange.com/q/115531/6191
Alexandre
A ter, 3/04/2018, 10:11, Alexandre Neto <senhor.neto at gmail.com> escreveu:
> Ah sorry,
> I got lost in translation. You are right, I was talking about the magnetic
> north, not the geodetic one.
> Meanwhile,  remembering that all UTM are Transverse Mercator, I don't
> think there's a CRS that will solve you question.
> I think you need to use some formula to convert the grid north measures to
> true north according to the CRS, and the latitude and longitude of the
> place.
> Alexandre
> A ter, 3/04/2018, 09:25, Springfield Harrison <stellargps at gmail.com>
> escreveu:
>> Alexandre,
>> I believe that true north is actually a constant oriented towards the
>> North Pole, i e 90 degrees north latitude. Also where all meridians
>> converge in the northern hemisphere.
>> The other North orientations are magnetic north and grid North and these
>> do vary as you suggested.
>> I do need to use a UTM projection but need bearings to be in degrees true
>> north.
>> Thanks Alexandre...
>> Cheers . . . . .   Spring
>> Samsung Tab 4
>> On Apr 2, 2018 4:27 PM, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>>> AFAIK, true bearing differs in time and location because of magnetic
>>> declination. So I don't think there is a such thing as a CRS with true
>>> bearings.
>>> Assuming you are working at regional level, find the magnetic
>>> declination for that region and remove it from your observations. Then draw
>>> the azimuth using the chosen CRS. I think 26910 will work just fine.
>>> If you are at a larger scale, then you may need to use different
>>> magnetic declination values for each observation.
>>> This may help:
>>> https://www.ngdc.noaa.gov/geomag/declination.shtml
>>> Best Regards,
>>> Alexandre Neto
>>> A seg, 2/04/2018, 23:54, Springfield Harrison <stellargps at gmail.com>
>>> escreveu:
>>>> Hello,
>>>> I am using CRS 26910, NAD83 / UTM zone 10N, and need to draw lines at
>>>> exact true bearings.  The Advanced Digitizing Tool seems to do this but
>>>> which CRS would I use to ensure that the bearing is True?
>>>> Thanks very much . . .
>>>> Cheers . . . . . Springfield Harrison
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/0163d82b/attachment.html>
