[Qgis-user] True North
Springfield Harrison stellargps at gmail.com
Tue Apr 3 13:47:31 PDT 2018
OK, thank you.  That formula is useful.
I assume that "North" for any projection will be grid North so that a
line drawn at 0° while using a UTM projection will point to grid North
if the drawing is re-projected using an un-projected CRS (where 0° is
true North)?
I wonder if I have that correct?  I will check some of the other
responses also.
Thanks very much…
Cheers . . . . . Spring Harrison
On 03-Apr-2018 02:15, Alexandre Neto wrote:
> Maybe something like this :
> https://gis.stackexchange.com/q/115531/6191
> Alexandre
> A ter, 3/04/2018, 10:11, Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>> escreveu:
>     Ah sorry,
>     I got lost in translation. You are right, I was talking about the
>     magnetic north, not the geodetic one.
>     Meanwhile,  remembering that all UTM are Transverse Mercator, I
>     don't think there's a CRS that will solve you question.
>     I think you need to use some formula to convert the grid north
>     measures to true north according to the CRS, and the latitude and
>     longitude of the place.
>     Alexandre
>     A ter, 3/04/2018, 09:25, Springfield Harrison
>     <stellargps at gmail.com <mailto:stellargps at gmail.com>> escreveu:
>         Alexandre,
>         I believe that true north is actually a constant oriented
>         towards the North Pole, i e 90 degrees north latitude. Also
>         where all meridians converge in the northern hemisphere.
>         The other North orientations are magnetic north and grid North
>         and these do vary as you suggested.
>         I do need to use a UTM projection but need bearings to be in
>         degrees true north.
>         Thanks Alexandre...
>         Samsung Tab 4
>         On Apr 2, 2018 4:27 PM, "Alexandre Neto"
>         <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> wrote:
>             AFAIK, true bearing differs in time and location because
>             of magnetic declination. So I don't think there is a such
>             thing as a CRS with true bearings.
>             Assuming you are working at regional level, find the
>             magnetic declination for that region and remove it from
>             your observations. Then draw the azimuth using the chosen
>             CRS. I think 26910 will work just fine.
>             If you are at a larger scale, then you may need to use
>             different magnetic declination values for each observation.
>             This may help:
>             https://www.ngdc.noaa.gov/geomag/declination.shtml
>             Best Regards,
>             Alexandre Neto
>             A seg, 2/04/2018, 23:54, Springfield Harrison
>                 Hello,
>                 I am using CRS 26910, NAD83 / UTM zone 10N, and need
>                 to draw lines at
>                 exact true bearings.  The Advanced Digitizing Tool
>                 seems to do this but
>                 which CRS would I use to ensure that the bearing is True?
>                 Thanks very much . . .
>                 Cheers . . . . . Springfield Harrison
>                 _______________________________________________
>                 Qgis-user mailing list
>                 Qgis-user at lists.osgeo.org
>                 <mailto:Qgis-user at lists.osgeo.org>
>                 List info:
>                 https://lists.osgeo.org/mailman/listinfo/qgis-user
>                 Unsubscribe:
>             Alexandre Neto
>             @AlexNetoGeo
>             http://sigsemgrilhetas.wordpress.com
>             http://gisunchained.wordpress.com
>     Alexandre Neto
>     @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
> 	Virus-free. www.avg.com
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180403/2e90e0f2/attachment.html>
