[Qgis-user] unable to deploy pythonscript
Frank Broniewski hallo at frankbroniewski.com
Thu Apr 5 00:33:47 PDT 2018
Hi Reginald,
pip and setuptools are both available through the OSGeo4W installer. You might as well try to use the OSGeo4W-Shell and not the default Windows CMD to install further python modules through pip or setuptools. Using the OSGeo4W-Shell takes care for setting up the right environment for Python.
HTH
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
www.frankbroniewski.com
-----Ursprüngliche Nachricht-----
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Reginald
Gesendet: Donnerstag, 5. April 2018 08:26
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] unable to deploy pythonscript
Maybe this question should be posted to the development mailinglist but as I am not subscribed there I post it here.
I have written a python script that depends on external python packages (python-docx, pymssq, and others). When I am trying to deploy it on other computers, where there is a standalone installation of QGIS-OSGeo4W-2.18.17-1-Setup-x86_64.exe  on Windows 7 and where I have opened a cmd window as administrator, executed a bat file that sets the path right for the python environment of the installed qgis, I get an error when I try to execute pip commands.
I execute them as : python -m pip install python-docx Then I get a mentioning of setuptools that are not installed.
I tried to install setuptools with pip but then I got a mentioning of there not being a version of setuptools.
The python version is 2.75. I downloaded setuptools and unzipped it and executed easy_install.py but then I got a mentioning that I might have no rights to write to this directory. As I am administrator this can not be the case.
How can I install setuptools or use pip to download external python packages for the qgis python installation?
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
