[Qgis-user] unable to deploy pythonscript
Reginald Carlier
Reginald.Carlier at ingelmunster.be
Thu Apr 5 01:06:57 PDT 2018
Hi Frank,
The problem is that the system administrator prefers just one version of QGIS without installing OSGEO4W on every PC.
So I'm stuck with this version of QGIS.
Regards,
Reginald Carlier
Deskundige GIS
Gemeente Ingelmunster, Oostrozebekestraat 4, 8770 Ingelmunster
T+32 51 33 74 39www.ingelmunster.be
Raadpleeg onze disclaimer
-----Oorspronkelijk bericht-----
Van: Frank Broniewski [mailto:hallo at frankbroniewski.com]
Verzonden: donderdag 5 april 2018 9:34
Aan: Reginald Carlier; qgis-user at lists.osgeo.org
Onderwerp: AW: [Qgis-user] unable to deploy pythonscript
Hi Reginald,
pip and setuptools are both available through the OSGeo4W installer. You might as well try to use the OSGeo4W-Shell and not the default Windows CMD to install further python modules through pip or setuptools. Using the OSGeo4W-Shell takes care for setting up the right environment for Python.
HTH
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
www.frankbroniewski.com
-----Ursprüngliche Nachricht-----
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Reginald
Gesendet: Donnerstag, 5. April 2018 08:26
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] unable to deploy pythonscript
Maybe this question should be posted to the development mailinglist but as I am not subscribed there I post it here.
I have written a python script that depends on external python packages (python-docx, pymssq, and others). When I am trying to deploy it on other computers, where there is a standalone installation of QGIS-OSGeo4W-2.18.17-1-Setup-x86_64.exe on Windows 7 and where I have opened a cmd window as administrator, executed a bat file that sets the path right for the python environment of the installed qgis, I get an error when I try to execute pip commands.
I execute them as : python -m pip install python-docx Then I get a mentioning of setuptools that are not installed.
I tried to install setuptools with pip but then I got a mentioning of there not being a version of setuptools.
The python version is 2.75. I downloaded setuptools and unzipped it and executed easy_install.py but then I got a mentioning that I might have no rights to write to this directory. As I am administrator this can not be the case.
How can I install setuptools or use pip to download external python packages for the qgis python installation?
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180405/e748ea8a/attachment.html>
