[Qgis-user] How to open QGIS from another application?
Richard Duivenvoorde rdmailings at duif.net
Mon Apr 9 04:09:10 PDT 2018
In addition, you could create a 'default project' which is started by
QGIS (or started because you use the command line option).
You can also let QGIS start up with a python script. Which could do the
things like zoom in to a certain feature etc. I'm not aware if that
python script receives the original command line parameters. Because if
that is the case, you could also give the x,y on the command line.
Regards,
Richard
On 09-04-18 12:39, Andreas Neumann wrote:
> Hi,
> This depends on the platform. On Linux it is just "qgis" (or if
> self-compiled non-default installation some other name or shell-script),
> on Windows it is a batch file - something like qgis.bat or qgis-ltr.bat
> For the startup options
> see https://docs.qgis.org/2.18/en/docs/user_manual/introduction/getting_started.html#command-line-options
> Greetings,
> Andreas
> On 2018-04-09 12:02, schildpad at gmx.net wrote:
>> Hi there
>> Does anybody knows what's the prompt to open QGIS from anthoer
>> application? In the other application, a system to govern information
>> about land properties (parcels), I'd like to put a link, so when
>> clicking on it, QGIS opens and jumps to the corresponding parcel.
>> Thanks and regards, Dani
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
