[Qgis-user] Unable to load qgisserver wms in qgis when more than 120 rasters
Andreas Neumann a.neumann at carto.net
Thu Apr 12 04:04:40 PDT 2018
Hi Reginald,
If the tiles are just adjacent tiffs from the same data set I would
recommend either merging them with gdalwarp into one image or use a VRT
file to create a virtual raster and see if this works.
Greetings,
Andreas
On 2018-04-12 12:49, Reginald wrote:
> Hi,
> I have a problem when I try to make a wmsservice for qgis server.
> When I load the wmsservice in another instance of qgis everything works as
> long as there are no more than about 120 rasters in my project. When I try
> to add more tiffs to my project I get a timeout when trying to load the wms
> in qgis.
> Are there any parameters I can set so the timeout doesn't happen or should I
> make multiple wms instances for the other tiles?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180412/44eb0ef2/attachment.html>
