[Qgis-user] no python console in QGIS 3 Ubuntu 17.10
Patrick Dunford enzedrailmaps at gmail.com
Sat Apr 14 03:17:56 PDT 2018
Jessie is a release for Debian, not Ubuntu. The releases for different
distros shouldn't be mixed, even though the distros are related.
To install from an ubuntugis repo, you need to have an extra PPA which
is described here:
https://trac.osgeo.org/ubuntugis/wiki/UbuntuGISRepository
On 14/04/18 21:30, Reginald wrote:
> Hi,
> An update of the situation:
> First I was using:
> deb https://qgis.org/debian-nightly-release artful
> resulted in : installation of qgis without python support
> Then I did following command :
> sudo apt-get purge --auto-remove qgis
> which should remove qgis completely
> Strange:
> In synaptic I saw that there were several packages with qgis in their name
> --> removed them
> next I put this in sources.list:
> deb     https://qgis.org/debian jessie main
> deb-src https://qgis.org/debian jessie main
> result: a lot of packages that can't be installed because of broken packages
> In synaptic I see no broken packages
> rebooted into recovery --> fix broken packages : nothing to fix
> changed sources.list:
> deb     https://qgis.org/debian artful main
> deb-src https://qgis.org/debian artful main
> result : qgis gets installed without python support
> deb     https://qgis.org/ubuntugis artful main
> deb-src https://qgis.org/ubuntugis artful main
> Fout:6 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu artful
> Release
>    404  Not Found
> Fout:10 https://qgis.org/ubuntugis artful Release
>    404  Not Found [IP: 2400:cb00:2048:1::681b:8adc 443]
> It seems that the release file is not installed in this repo.
> How can I install qgis with python support?
> Regards,
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
