[Qgis-user] no python console in QGIS 3 Ubuntu 17.10
Reginald Reginald.Carlier at ingelmunster.be
Sat Apr 14 02:30:46 PDT 2018
An update of the situation:
First I was using:
deb https://qgis.org/debian-nightly-release artful
resulted in : installation of qgis without python support
Then I did following command :
sudo apt-get purge --auto-remove qgis
which should remove qgis completely
Strange:
In synaptic I saw that there were several packages with qgis in their name
--> removed them
next I put this in sources.list:
deb     https://qgis.org/debian jessie main
deb-src https://qgis.org/debian jessie main
result: a lot of packages that can't be installed because of broken packages
In synaptic I see no broken packages
rebooted into recovery --> fix broken packages : nothing to fix
changed sources.list:
deb     https://qgis.org/debian artful main
deb-src https://qgis.org/debian artful main
result : qgis gets installed without python support
deb     https://qgis.org/ubuntugis artful main
deb-src https://qgis.org/ubuntugis artful main
Fout:6 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu artful
Release
  404  Not Found
Fout:10 https://qgis.org/ubuntugis artful Release
  404  Not Found [IP: 2400:cb00:2048:1::681b:8adc 443]
It seems that the release file is not installed in this repo.
How can I install qgis with python support?
Regards,
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
