[Qgis-user] QGIS & CityGML?
b.j.kobben at utwente.nl b.j.kobben at utwente.nl
Mon Apr 16 00:55:02 PDT 2018
Reading CityGML is possible, it is after all well-behaved GML. Using GDAL or better using the tudelft.nl tools mentioned by Tobias to convert it to a PostGIS database. And visualising it then is probably also OK, but only in 2D, not the way I suspect you’d want to, i.e.  in a 3D-viewing environment...
Barend Köbben
On 16/04/2018, 09:41, "Qgis-user on behalf of Tobias Wendorff" <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> on behalf of tobias.wendorff at tu-dortmund.de<mailto:tobias.wendorff at tu-dortmund.de>> wrote:
Hi Mike.
Am Mo, 16.04.2018, 09:34 schrieb Elstermann, Mike:
How can I read/visualize CityGML in QGIS?
CityGML exists in several flavors, I don't think, QGIS supports
it the native way. You have to use FME to convert it or try it
the GDAL way. EvenR has added much GMLAS in the past, which makes
it able to parse some kind of CityGML-stuff:
http://www.gdal.org/drv_gmlas.html
https://3d.bk.tudelft.nl/svitalis/citygml/gdal/2017/07/24/messing-around-with-citygml-on-gdal-2.2.html
HTH,
Tobias
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180416/f714a15f/attachment.html>
