[Qgis-user] QGIS & CityGML?
Elstermann, Mike Mike.Elstermann at itc-halle.de
Tue Apr 17 04:22:56 PDT 2018
THX! :-)
mikeE.
> Am 16.04.2018 um 09:55 schrieb b.j.kobben at utwente.nl:
> Reading CityGML is possible, it is after all well-behaved GML. Using GDAL or better using the tudelft.nl tools mentioned by Tobias to convert it to a PostGIS database. And visualising it then is probably also OK, but only in 2D, not the way I suspect you’d want to, i.e.  in a 3D-viewing environment...
> Barend Köbben
> On 16/04/2018, 09:41, "Qgis-user on behalf of Tobias Wendorff" <qgis-user-bounces at lists.osgeo.org on behalf oftobias.wendorff at tu-dortmund.de> wrote:
> Hi Mike.
> Am Mo, 16.04.2018, 09:34 schrieb Elstermann, Mike:
>> How can I read/visualize CityGML in QGIS?
> CityGML exists in several flavors, I don't think, QGIS supports
> it the native way. You have to use FME to convert it or try it
> the GDAL way. EvenR has added much GMLAS in the past, which makes
> it able to parse some kind of CityGML-stuff:
> http://www.gdal.org/drv_gmlas.html
> https://3d.bk.tudelft.nl/svitalis/citygml/gdal/2017/07/24/messing-around-with-citygml-on-gdal-2.2.html
> HTH,
> Tobias
> Qgis-user mailing list
