[Qgis-user] How retrieve the scale value in a composer report
Alexandre Neto senhor.neto at gmail.com
Thu Apr 19 02:32:35 PDT 2018
Hi!
It's a bit of a workaround if you were planing to insert the numeric scale
in the middle of other text, but you can add a scalebar and change it's
style to numeric.
Hope it helps.
Andrea Peri <aperi2007 at gmail.com> escreveu no dia quinta, 19/04/2018 às
07:21:
> Hi,
> I need to produce some reports using the composer and the Atlas.
> In each of them I need to add the scale value.
> So I try adding a textbox and the value $scale.
> Unfortunately I see it return always 0 value.
> This is confirmed in the help where is write that the $scale not
> alwaysreturn the real scale value, but in some context it return 0 value.
> There is some other choice to have the scale value in a composer+atlas
> output ?
> I'm using the qgis 2.18.
> Many thx.
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180419/278cc0b2/attachment.html>
