[Qgis-user] QGIS Saving TAB as SHP
Richard McDonnell richard.mcdonnell at opw.ie
Thu Apr 19 07:05:53 PDT 2018
Afternoon all,
I have a slight issue, there are a number of MapInfo Tab Files which we
want to convert to Shapefile, but they do not convert correctly.
The issue arises with Rings/Holes in the Polygons, when you save the TAB
file as a shapefile, some of them are not displaying correct, they
overlay the hole as another polygon.
The issue seems to be related to the direction the hole was
digitised/generated to. The issue can also be replicated outside of QGIS
by running ogr2ogr, so it seems to be a GDAL/OGR ESRI Shapefile Driver
issue.
Now in saying all that, QGIS 3 seems to be able to fix the issue by
running, /*Fix geometries */from the Processing Toolbox.
My question is, Is there a way to fix the OGR Driver to fix the issue,
or a tick box under /*Save Vector Layer as... */to run/implament the
/*Fix geometries */tool as part of the save process?
This is an issue, which pops up regularly online, with no solution to date.
Regards & Thanks in advance.
Richard McDonnell
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180419/65975a30/attachment.html>
