[Qgis-user] QGIS Saving TAB as SHP
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Thu Apr 19 15:10:48 PDT 2018
I would do a bug report https://trac.osgeo.org/gdal.  Have you tried fixing the geometry before exporting?  The problem could be in the tab file.  You could try to save in another format to see if the error is also reproduced.
Nicolas
> Le 19 avr. 2018 à 10:05, Richard McDonnell <richard.mcdonnell at opw.ie> a écrit :
> Afternoon all,
> I have a slight issue, there are a number of MapInfo Tab Files which we want to convert to Shapefile, but they do not convert correctly.
> The issue arises with Rings/Holes in the Polygons, when you save the TAB file as a shapefile, some of them are not displaying correct, they overlay the hole as another polygon.
> The issue seems to be related to the direction the hole was digitised/generated to. The issue can also be replicated outside of QGIS by running ogr2ogr, so it seems to be a GDAL/OGR ESRI Shapefile Driver issue.
> Now in saying all that, QGIS 3 seems to be able to fix the issue by running, Fix geometries  from the Processing Toolbox.
> My question is, Is there a way to fix the OGR Driver to fix the issue, or a tick box under Save Vector Layer as... to run/implament the Fix geometries tool as part of the save process?
> This is an issue, which pops up regularly online, with no solution to date.
> Regards & Thanks in advance.
> Richard McDonnell
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180419/b9ef45b1/attachment.html>
