[Qgis-user] Working with irregular magnetometry data points - converting them to an image
Benjamin Ducke benducke at fastmail.fm
Mon Apr 23 12:30:06 PDT 2018
Hi Calvin,
On 21/04/18 22:37, C Hamilton wrote:
> Ben,
> I have been taking a look at this and I am able to get it rasterized,
> but I am not finding the fill in QGIS. All I see under GRASS GIS 7 is
> r.fill.dir and r.fillnulls. Where do I find r.fill.stats? It appears
> that the version of GRASS in QGIS is 7.4
That's strange. I am running QGIS 3.0.1 and GRASS 7.4.0.
I can confirm that r.fill.stats is present in GRASS
7.4.0, but it does not appear in the list of GRASS 7
modules under QGIS' Processing.
I can only guess that the QGIS Processing plug-in
for some reason skips that particular GRASS command.
I guess you could try launching GRASS 7 directly
and using r.fill.stats from within the GRASS shell
or GRASS GUI.
Cheers,
Ben
> Thanks,
> On Fri, Apr 20, 2018 at 1:10 PM, Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>> wrote:
>     Hi Calvin,
>     On 20/04/18 18:46, Richard McDonnell wrote:
>     > Calvin,
>     > Under Processing Toolbox, Type interpolation into the search
bar, the
>     > tool you want can be found there.
>     None of the typical GIS interpolation tools will be
>     of much help here, since they have all been optimized
>     to work with relatively sparse data. They will be
>     too inefficient for high-resolution geomagnetic data.
>     You data is already dense, with some gaps. So you need
>     something that is fast and efficient for small
>     interpolation radii, and will not produce too many
>     artefacts.
>     If you can use the GRASS7 plug-in from within QGIS,
>     than this is a good processing path:
>     1. Rasterize your data points, using a cell size
>     small enough so that you don't have too much information
>     loss (i.e. not too many occurrences of more than one data
>     point per cell). This might take a little trial and error
>     to find good settings. You should end up with a raster
>     where you have gaps of max. 1-3 empty cells between cells
>     with measurement data.
>     Now you need to fill these relatively small gaps.
>     2. Use r.fill.stats from current GRASS 7.4:
>     https://grass.osgeo.org/grass74/manuals/r.fill.stats.html
>     <https://grass.osgeo.org/grass74/manuals/r.fill.stats.html>
>     ... because that has been designed exactly for the
>     purpose. Set the interpolation radius as small as
>     possible, so that it just manages to fill the gaps.
>     With a small radius, r.fill.stats is very fast and
>     memory efficient, even on very large raster datasets.
>     Note that r.fill.stats is part of GRASS 7 only since
>     version 7.4. If your QGIS ships with an earlier
>     version, then you might have to update your GRASS 7
>     binaries manually.
>     Best,
>     Ben
>     > Regards,
>     > Richard.
>     > On 20/04/2018 16:42, C Hamilton wrote:
>     >> I don't know how many of you have worked with archaeological
>     >> magnetormetry data, but I have been asked to help with magnetometry
>     >> data of the ancient Mound Builders in North America. I am
looking for
>     >> some suggestion on how to best turn the irregular magnetic data
points
>     >> into an image.
>     >> I see an Interpolation plugin that perhaps is the solution, but
I also
>     >> see that it is not part of QGIS 3. Is this because it has not been
>     >> ported yet, or is not going to be porter, or is there a better
solution?
>     >> I don't know if any of the Lidar tools would work for this or not.
>     >> LASTools is a commercial product and the locked version only works
>     >> with small data sets and adds noise unless you purchase a
license. At
>     >> least that is how it was the last time I used it.
>     >> Thanks for any suggestions.
>     >> Calvin
>     >> _______________________________________________
>     >> Qgis-user mailing list
>     >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     > *_Richard McDonnell_*
>     > *GIS Specialist PgD GIS AssocSCSI*
>     > *OPW FRM Data Management*
>     > *52 Stephens Green, Dublin 2.*
>     > TEL: 01 6476543
>     > <http://www.opw.ie/>
>     > Email Disclaimer: http://www.opw.ie/en/disclaimer/
>     <http://www.opw.ie/en/disclaimer/>
>     Dr. Benjamin Ducke
>     Deutsches Archäologisches Institut (DAI)
>     Zentrale Berlin, IT-Referat
>     * Projekt "Stunde Null" *
Dr. Benjamin Ducke
> Ben,
> Thanks,
>     Hi Calvin,
>     > Calvin,
>     > Under Processing Toolbox, Type interpolation into the search bar, the
>     artefacts.
>     binaries manually.
>     Best,
>     Ben
>     > Regards,
>     > Richard.
>     >> data of the ancient Mound Builders in North America. I am looking for
>     >> some suggestion on how to best turn the irregular magnetic data points
>     >> into an image.
>     >> I see an Interpolation plugin that perhaps is the solution, but I also
>     >> ported yet, or is not going to be porter, or is there a better solution?
>     >> with small data sets and adds noise unless you purchase a license. At
>     >> Calvin
>     > TEL: 01 6476543
>     Dr. Benjamin Ducke
Dr. Benjamin Ducke
