[Qgis-user] Working with irregular magnetometry data points - converting them to an image
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Apr 20 13:03:35 PDT 2018
Hi Calvin,
I see a lot of people have been corresponding.  I am an archaeologist and can help if you don’t figure thing out.  How many points are you looking at?  You could also use cloud compare to make a DEM.  I use Gdal grid with nearest neighbour for very big data sets.
Nicolas
> Le 20 avr. 2018 à 11:42, C Hamilton <adenaculture at gmail.com> a écrit :
> I don't know how many of you have worked with archaeological magnetormetry data, but I have been asked to help with magnetometry data of the ancient Mound Builders in North America. I am looking for some suggestion on how to best turn the irregular magnetic data points into an image.
> I see an Interpolation plugin that perhaps is the solution, but I also see that it is not part of QGIS 3. Is this because it has not been ported yet, or is not going to be porter, or is there a better solution?
> I don't know if any of the Lidar tools would work for this or not. LASTools is a commercial product and the locked version only works with small data sets and adds noise unless you purchase a license. At least that is how it was the last time I used it.
> Thanks for any suggestions.
> Calvin
> Qgis-user mailing list
