[Qgis-user] [QGIS-Developer] Working with irregular magnetometry data points - converting them to an image
Carlo A. Bertelli (Charta s.r.l.) carlo.bertelli at gmail.com
Sat Apr 21 00:00:47 PDT 2018
Specialists may suggest a more focused approach, but you can use several
tools and approaches.
You can start with the PDAL library (pdal.io), use the tools in GDAL (grid
tools) or prepare a workflow using GRASS algorithms in Processing.
c
Il ven 20 apr 2018 17:42 C Hamilton <adenaculture at gmail.com> ha scritto:
> I don't know how many of you have worked with archaeological magnetormetry
> data, but I have been asked to help with magnetometry data of the ancient
> Mound Builders in North America. I am looking for some suggestion on how to
> best turn the irregular magnetic data points into an image.
> I see an Interpolation plugin that perhaps is the solution, but I also see
> that it is not part of QGIS 3. Is this because it has not been ported yet,
> or is not going to be porter, or is there a better solution?
> I don't know if any of the Lidar tools would work for this or not.
> LASTools is a commercial product and the locked version only works with
> small data sets and adds noise unless you purchase a license. At least that
> is how it was the last time I used it.
> Thanks for any suggestions.
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180421/f13f8de9/attachment.html>
