[Qgis-user] Transfer color style from one raster to the other rasters.
Alexandre Neto senhor.neto at gmail.com
Wed Dec 5 06:34:09 PST 2018
Hi!
Why don't you force a larger range in the first layer (change min and max)?
More, if the final objective is to compare those rasters, they really need
to have the same range, otherwise the same value won't have the same color
in each raster.
Hope it helped.
Alexandre Neto
Hugo Nicolau Barbosa de Gusmão <hugonbgg at gmail.com> escreveu no dia quarta,
5/12/2018 às 14:05:
> Hello everyone!
> I have a raster set and I need to classify them using the "pseudo color
> singleband" with "RdYlGn". What I'm trying to do is classify a raster and
> copy the style to the others, but it does not work because it limits the
> range to the values of the first raster I used as a template.
> Is there a way to classify the raster, copy the style to others and it
> refresh the range automatically?
> Thank you!
> [image: image.png]
> [image: image.png]
> Qgis-user mailing list
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181205/cbe94c79/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181205/cbe94c79/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181205/cbe94c79/attachment-0003.png>
