[Qgis-user] Anybody to confirm this WFS problem?
Andrea Aime andrea.aime at geo-solutions.it
Sun Dec 16 05:09:39 PST 2018
On Fri, Dec 14, 2018 at 8:32 PM magerlin <MAP at ramboll.dk> wrote:
> I just need to clarify, that I am just trying to ad a WFS layer to a
> completely blank project in a QGIS3 project on my standalone laptop.
> The data are from the official provider of maps by the state of Denmark (so
> I can only say that 1/5800000 of the server is mine ;-) ....
> So I am not sure what you mean when saying "Your server" and "Your data"
> below?
Forget about the "your" attribute, everything else is accurate.
GeoServer has needed primary keys to support paging since 10 years ago, when
this ticket got worked on (some of the dates are off because bits of the
infrastructure
got moved, both jira and the wiki got moved, but it happened in 2008):
   - https://osgeo-org.atlassian.net/browse/GEOT-1794
   https://github.com/geotools/geotools/wiki/feature-paging-and-query-capabilities
Setting up a WFS server backed by a table without primary keys is
problematic for other reasons too,
for example, features need to be identifiable via id.
Long story short, it would still be a good idea for someone to contact the
server administrator and
let them know they should rectify/improve their setup.
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181216/749f85a0/attachment.html>
