[Qgis-user] how to properly reference longitude values in different datasets
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Sat Dec 29 03:38:43 PST 2018
Hi Lee,
I had the same issue:
https://github.com/lutraconsulting/MDAL/issues/66
Could you open a ticket for GFS and an example file?
Regards
Saber
On Sat, 29 Dec 2018, 00:16 Lee Eddington <lee.w.eddington at gmail.com wrote:
> Coming back to this…I did some reading on MDAL and tried the instructions
> found at:
> https://www.lutraconsulting.co.uk/blog/2018/10/18/mdal/
> trying to load the GFS dataset as a mesh instead of a raster, but I get
> the following error message:
> Tools::BufferedFileWriter::open: Cannot open file.: unspecified
> upstream_category error
> I also tried loading the ECMWF_ERA-40_subset.nc dataset linked to the blog
> post and get an error message saying it is an invalid data source.
> I’m using QGIS version 3.4.1-Madeira on MacOSX 10.14.2
> Lee
> On Dec 21, 2018, at 2:46 PM, Lee Eddington <lee.w.eddington at gmail.com>
> wrote:
> As a raster.
> Sent from my iPhone
> On Dec 21, 2018, at 12:09 AM, Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk> wrote:
> Did you open your layer as Mesh layer or Raster?
> Cheers
> Saber
> On Fri, 21 Dec 2018 at 05:59, Lee Eddington <lee.w.eddington at gmail.com>
> wrote:
>> That worked.
>> Thanks,
>> Lee
>> On Dec 20, 2018, at 6:06 AM, Saber Razmjooei <
>> Climate Data Operator (CDO):
>> https://code.mpimet.mpg.de/projects/cdo/
>> cdo sellonlatbox,-180,180,-90,90 input.grib output.grib
>> Regards
>> Saber
>> On Thu, 20 Dec 2018 at 13:00, Lee Eddington <lee.w.eddington at gmail.com>
>> wrote:
>>> Can you point me to the external tools?
>>> Thanks,
>>> Lee
>>> On Dec 20, 2018, at 12:46 AM, Saber Razmjooei <
>>> This is a known issue and can be fixed with some external tools.
>>> I have filed a bug:
>>> https://issues.qgis.org/issues/20853
>>> And hopefully get around to fix it in 3.6
>>> Regards
>>> Saber
>>> On Thu, 20 Dec 2018 at 01:44, Lee Eddington <lee.w.eddington at gmail.com>
>>> wrote:
>>>> I’m pretty new to QGIS and am trying to figure out how to modify
>>>> longitude values of layers.  I was able to add a raster layer in GRIB2
>>>> format (NCEP global meteorological data).  The longitude values range from
>>>> 0 to 360 degrees.  I’m able to view and do calculations on the data with no
>>>> problem.  I also added shaded relief and coastline data from Natural
>>>> Earth.  This data has longitude values from -180 to 180 degrees.  So from
>>>> -180 to 0 degrees I only see the Natural Earth data, from 0 to 180 degrees
>>>> I see both datasets and from 180 to 360 degrees I only see the GRIB2 data.
>>>> I want both datasets to be referenced the same with regards to longitude
>>>> (-180 to 180, 0 to 360 or whatever).  It seems like this should be a fairly
>>>> easy problem to fix by either adding 180 degrees to longitudes from the
>>>> Natural Earth data or subtracting 180 from the GRIB2 longitudes, but I
>>>> can’t figure out how to do it.
>>>> I’m using QGIS version 3.4.1-Madeira.  The CRS I’m working in is what
>>>> QGIS put the GRIB2 data into when I added it:   * Generated CRS
>>>> (+proj=longlat +a=6371229 +b=6371229 +no_defs)
>>>> Thanks,
>>>> Lee
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Saber Razmjooei
>>> +44 (0)7568 129733
>> Saber Razmjooei
>> +44 (0)7568 129733
> Saber Razmjooei
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20181229/51c425fe/attachment.html>
