[Qgis-user] Google Satellite Images v3
Tobias Wendorff tobias.wendorff at tu-dortmund.de
Mon Feb 12 00:39:55 PST 2018
Hi Jürgen,
Am Mo, 12.02.2018, 09:30 schrieb Jürgen E. Fischer:
>> Isn't this against Google's terms of usage to directly access
>> the tiles without using the API?
> I think it is.  Usage via the QuickMapServices plugin is in the
> same gray area.
> Not sure if usage via the OpenLayers plugin is either - that's
> at least using the API, but using browser components in background
> is probably also not the intended usage - but probably dark white.
Okay, then better won't use it on corporate environment and I won't
recommend it to any corporate user without a warning :)
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
Sorry to be offtopic, but you missed the space after the two dashes.
It's "-- " before the signature :)
Best regards,
Tobias
