[Qgis-user] Move multiple layer at the same time
gam17 at riseup.net gam17 at riseup.net
Wed Jul 4 00:38:04 PDT 2018
Hi Marco,
   you can use qad plugin. If you are using spanish localization run
DESPLAZA command, if you are using english version run MOVE command.
For further info search "MOVE AUTOCAD" on the web.
bye
gam17
Use the
> Hi All!
> I would like to move multiple layers (point, line and polygon) at the
> same time in QGIS. Is it possible?
> All layers are relatively georrefereced, and I want to change their
> locations at once, using known control points from one of the layers.
> Best regards!
> Qgis-user mailing list
