[Qgis-user] Move multiple layer at the same time
Marco Antônio Ferreira Pedrosa marcomottim at gmail.com
Wed Jul 4 11:55:17 PDT 2018
Thanks a lot, Gam17!
Marcão
skype: marco.afp
Em qua, 4 de jul de 2018 às 04:38, <gam17 at riseup.net> escreveu:
> Hi Marco,
>    you can use qad plugin. If you are using spanish localization run
> DESPLAZA command, if you are using english version run MOVE command.
> For further info search "MOVE AUTOCAD" on the web.
> bye
> gam17
> Use the
> > Hi All!
> > I would like to move multiple layers (point, line and polygon) at the
> > same time in QGIS. Is it possible?
> > All layers are relatively georrefereced, and I want to change their
> > locations at once, using known control points from one of the layers.
> > Best regards!
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180704/0227e19b/attachment.html>
