[Qgis-user] Save label position in 3.2
Richard McDonnell richard.mcdonnell at opw.ie
Fri Jul 6 03:04:06 PDT 2018
Lene,
*Hold the Press*!!!!, I take back my last email!! Hope its not too late!!!
I have a solution for you!
https://gis.stackexchange.com/questions/288170/qgis-3-2-0-how-to-share-auxiliary-data-between-projects
Use QGIS 3 to create the additional fields with the field calculator,
see examples below
for example:
*Field Name            Field Type                         Expression*
lab_x                 Decimal (Real)   (20,4)
"auxiliary_storage_labeling_positionx"
lab_y                 Decimal (Real)   (20,4)
"auxiliary_storage_labeling_positiony"
lab_rot              Decimal (Real)   (20,4)
"auxiliary_storage_labeling_labelrotation"
Then set up the Auxiliary fealds to use your new attributes, this should then work for QGISCloud!!
Regards,
Richard.
On 06/07/2018 10:30, Richard McDonnell wrote:
> Hi,
> It seems, as QGIS 3 is not LTR yet, its not fully supported by QGISCloud.
> The only solution seems to be, to open the project in QGIS 2.18, add
> the x,y and rotation attribution and relocate/rotate your labels again.
> Sorry I cant be of more help.
> Regards,
> Richard.
> On 06/07/2018 09:53, Lene Fischer wrote:
>> Yes this is correct – but only if you move the labels – What I want
>> is the position for the labels without editing.
>> I need this for web presentation. When I export to QGISCLOUD the
>> labels is not presented – so I have to make a workaround…
>> Regards
>> Lene Fischer
>> *Fra:*Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
>> *Sendt:* 6. juli 2018 10:23
>> *Til:* Lene Fischer
>> *Emne:* Re: [Qgis-user] Save label position in 3.2
>> Hi Lene,
>> In QGIS 2.1X If you create X,Y and rotation attributes, when you use
>> the move or rotate labels tools, the attribution is automatically
>> updated. I would assume its the same!, though open to correction!
>> Hope this helps.
>> Regards
>> On 06/07/2018 09:12, Lene Fischer wrote:
>>     Hi,
>>     I´m using 3.2 and trying out the label function. Wonderful new possibilities!
>>     I would like to save the z, y and rotation for the labels, but I can only get the information for labels I have edited in the "auxiliary_storage_labeling_positionx".
>>     Are there any other way to capture the positions ?
>>     Regards
>>     Lene Fischer
>>     Associate Professor
>>     University of Copenhagen
>>     Department of Geoscience and Natural Resource Management
>>     Forest and Landscape College
>>     Nødebovej 77a
>>     3480 Fredensborg
>>     Denmark
>>     MOB +45 40115084
>>     lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> *_Richard McDonnell_*
>> *GIS Specialist PgD GIS AssocSCSI*
>> *OPW FRM Data Management*
>> *52 Stephens Green, Dublin 2.*
>> TEL: 01 6476543
>> <http://www.opw.ie/>
>> Email Disclaimer: http://www.opw.ie/en/disclaimer/
> TEL: 01 6476543
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180706/9b816d6c/attachment.html>
