[Qgis-user] Save label position in 3.2
Lene Fischer lfi at ign.ku.dk
Fri Jul 6 23:49:40 PDT 2018
Hi Richard,
Thanks a lot – this worked. Now I have labels on the roads. https://qgiscloud.com/UAS_KU/tur/?e=705743%3B6213558%3B708994%3B6215150&crs=EPSG%3A25832&t=tur&l=DTK%2Fkort25%20klassisk%2Cvejnavn%2Clang_rute%2Ckort_rute%2Csteder&st=
But I still would like to know how to retrieve the coordinates in the attribute table.
Kind regards
Lene Fischer
Fra: Richard McDonnell [mailto:richard.mcdonnell at opw.ie]
Sendt: 6. juli 2018 12:04
Til: qgis-user at lists.osgeo.org
Cc: Lene Fischer
Emne: Re: [Qgis-user] Save label position in 3.2
Lene,
Hold the Press!!!!, I take back my last email!! Hope its not too late!!!
I have a solution for you!
https://gis.stackexchange.com/questions/288170/qgis-3-2-0-how-to-share-auxiliary-data-between-projects
Use QGIS 3 to create the additional fields with the field calculator, see examples below
for example:
Field Name            Field Type                                                         Expression
lab_x                 Decimal (Real)   (20,4)                 "auxiliary_storage_labeling_positionx"
lab_y                 Decimal (Real)   (20,4)                 "auxiliary_storage_labeling_positiony"
lab_rot              Decimal (Real)   (20,4)                 "auxiliary_storage_labeling_labelrotation"
Then set up the Auxiliary fealds to use your new attributes, this should then work for QGISCloud!!
Regards,
Richard.
On 06/07/2018 10:30, Richard McDonnell wrote:
It seems, as QGIS 3 is not LTR yet, its not fully supported by QGISCloud.
The only solution seems to be, to open the project in QGIS 2.18, add the x,y and rotation attribution and relocate/rotate your labels again.
Sorry I cant be of more help.
Regards,
Richard.
On 06/07/2018 09:53, Lene Fischer wrote:
Yes this is correct – but only if you move the labels – What I want is the position for the labels without editing.
I need this for web presentation. When I export to QGISCLOUD the labels is not presented – so I have to make a workaround…
Regards
Lene Fischer
Sendt: 6. juli 2018 10:23
Til: Lene Fischer
Hi Lene,
In QGIS 2.1X If you create X,Y and rotation attributes, when you use the move or rotate labels tools, the attribution is automatically updated. I would assume its the same!, though open to correction!
Hope this helps.
Regards
On 06/07/2018 09:12, Lene Fischer wrote:
I´m using 3.2 and trying out the label function. Wonderful new possibilities!
I would like to save the z, y and rotation for the labels, but I can only get the information for labels I have edited in the "auxiliary_storage_labeling_positionx".
Are there any other way to capture the positions ?
Regards
Lene Fischer
Associate Professor
University of Copenhagen
Department of Geoscience and Natural Resource Management
Forest and Landscape College
Nødebovej 77a
3480 Fredensborg
Denmark
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
[http://www.opw.ie/en/media/opw-logo-december-2016.gif]<http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
Richard McDonnell
TEL: 01 6476543
Richard McDonnell
TEL: 01 6476543
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180707/49b079ce/attachment.html>
