[Qgis-user] Saving a CRS EPSG 4326 project as CRS EPSG 3857
Patrick Dunford enzedrailmaps at gmail.com
Fri Jul 6 21:52:57 PDT 2018
Good day
I have some Qgis map projects that were originally in EPSG 4326 that I
am converting to EPSG 3857 without OTF transformation.
All of the layers in the projects have been resaved as EPSG:3857 layers
and display as expected in the map canvas.
In the projects I have changed the project CRS in the project properties
to EPSG:3857 and saved the project into a new project file.
However at the moment there is a problem with the coordinates that are
displayed at the bottom of the map canvas window. The coordinates being
displayed are EPSG:4326 coordinates, not the ones for EPSG:3857 that I
have changed the project properties into.
Furthermore I have looked in the project's source file and found it
still references EPSG:4326 within the file. Specifically the section
containing this reference. This section is near the bottom of the
project file.
</layerorder>
   <properties>
     <WMSContactOrganization type="QString"></WMSContactOrganization>
     <Identify>
       <disabledLayers type="QStringList"/>
     </Identify>
     <WMSServiceAbstract type="QString"></WMSServiceAbstract>
     <WMSUseLayerIDs type="bool">false</WMSUseLayerIDs>
     <WMSUrl type="QString"></WMSUrl>
     <SpatialRefSys>
       <ProjectCrs type="QString">EPSG:4326</ProjectCrs>
       <ProjectionsEnabled type="int">1</ProjectionsEnabled>
       <ProjectCRSID type="int">3452</ProjectCRSID>
       <ProjectCRSProj4String type="QString">+proj=longlat +datum=WGS84
+no_defs</ProjectCRSProj4String>
     </SpatialRefSys>
How can I complete the conversion of my project file to the new CRS so
that the coordinates displayed in the map canvas are the correct ones
for that CRS.
