[Qgis-user] Saving a CRS EPSG 4326 project as CRS EPSG 3857
Andre Joost andre+joost at nurfuerspam.de
Sun Jul 8 05:22:03 PDT 2018
Hi Patrick,
Am 07.07.18 um 06:52 schrieb Patrick Dunford:
> However at the moment there is a problem with the coordinates that are
> displayed at the bottom of the map canvas window. The coordinates being
> displayed are EPSG:4326 coordinates, not the ones for EPSG:3857 that I
> have changed the project properties into.
In the Project Properties, have a look in the Gerenral tab. You can set
the coordinate display either todegrees or map units. For EPSG:4326 it
was the same, for EPSG:3857 it is different.
> Furthermore I have looked in the project's source file and found it
> still references EPSG:4326 within the file. Specifically the section
> containing this reference. This section is near the bottom of the
> project file.
> </layerorder>
>    <properties>
>      <WMSContactOrganization type="QString"></WMSContactOrganization>
>      <Identify>
>        <disabledLayers type="QStringList"/>
>      </Identify>
>      <WMSServiceAbstract type="QString"></WMSServiceAbstract>
>      <WMSUseLayerIDs type="bool">false</WMSUseLayerIDs>
>      <WMSUrl type="QString"></WMSUrl>
>      <SpatialRefSys>
>        <ProjectCrs type="QString">EPSG:4326</ProjectCrs>
>        <ProjectionsEnabled type="int">1</ProjectionsEnabled>
>        <ProjectCRSID type="int">3452</ProjectCRSID>
>        <ProjectCRSProj4String type="QString">+proj=longlat +datum=WGS84
> +no_defs</ProjectCRSProj4String>
>      </SpatialRefSys>
It might be necessary to re-add the WMS to your project using the new
project CRS, or the WMS does not offer EPSG:3857.
HTH,
andre Joost
