[Qgis-user] Python error when trying to do a slope analysis in a DEM raster file
larry mason
glmason.lm at gmail.com
Mon Jul 9 10:29:03 PDT 2018
I know I should read the documentation just not sure where to find it. I'm
trying to do a slope analysis of a DEM raster layer... I get the following
python stack trace:
snip---------------
An error has occurred while executing Python code:
AttributeError: 'slope' object has no attribute 'preprocessParameters'
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\gui\menus.py",
line 181, in
action.triggered.connect(lambda: _executeAlgorithm(alg))
line 227, in _executeAlgorithm
dlg = alg.createCustomParametersWidget(None)
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithm.py",
line 62, in createCustomParametersWidget
return GdalAlgorithmDialog(self)
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\algs\gdal\GdalAlgorithmDialog.py",
line 58, in __init__
self.mainWidget().parametersHaveChanged()
line 110, in parametersHaveChanged
parameters = self.parent.getParameterValues()
File "C:/PROGRA~1/QGIS3~1.0/apps/qgis/./python/plugins\processing\gui\AlgorithmDialog.py",
line 119, in getParameterValues
return self.algorithm().preprocessParameters(parameters)
Python version: 3.6.0 (v3.6.0:41df79263a11, Dec 23 2016, 08:06:12) [MSC
v.1900 64 bit (AMD64)]
QGIS version: 3.0.0-Girona Girona, 001c80b0c3
end snip-----------------------
So I'm wondering if I need to set anything up for QGIS is use python
modules. Or where one sets up preprocessing Parameters. Any good tutorials
on loading DEMs. configuring properties, and running analysis. Thanks,
Larry
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality6&>
Sender
notified by
Mailtrack
07/09/18,
12:25:29 PM
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180709/e31e2cc7/attachment.html>
