[Qgis-user] Export segment values in polyline in excel
daniel pinto daniel.ar.pinto at gmail.com
Wed Jul 11 02:37:04 PDT 2018
Thank you, mas it it's not returnig the value of the segments, it's
returting the total lenght.... i have more than 6000 segmnst to measure in
diferenr polilines....  thank you anyway
daniel pinto
arqueólogo
91 869 1397
rua de Arouca, nº 10, 1º esq, 3810-050 - Aveiro
A sexta, 15/06/2018, 13:29, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
escreveu:
> Hi,
> Just use the field calculator to create a new column with the length.
> Then you can save the file in csv and export it to Excel.
> http://www.qgistutorials.com/en/docs/calculating_line_lengths.html
> Nicolas
> Le 15 juin 2018 à 07:48, daniel pinto <daniel.ar.pinto at gmail.com> a
> écrit :
> Dear sirs i have an image with several polylines to measure the elements
> in need in said image.... i need to have the segments measure of each
> polyline exported to excel... thru the atribute table... is that
> possible???
> Thank you in advance!!
> daniel pinto
> arqueólogo
> 91 869 1397
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180711/505775e4/attachment.html>
