[Qgis-user] Qgis 3.2.0 crashes at DigitizingTools plugin activation.
Nyall Dawson
nyall.dawson at gmail.com
Wed Jul 18 20:14:13 PDT 2018
On Thu, 19 Jul 2018 at 12:03, Fernando M. Roxo da Motta <petro at roxo.org> wrote:
> Hi all,
> I have just updated my machine to the Xubuntu 18.04 LTS:
> $ lsb_release -a
> LSB Version:
> core-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch
> Distributor ID: Ubuntu Description: Ubuntu 18.04 LTS
> Release: 18.04
> Codename: bionic
> The machine is a Asus Republic of Gamers:
> $ uname -a
> Linux cabore 4.15.0-24-generic #26-Ubuntu SMP Wed Jun 13 08:44:47 UTC
> 2018 x86_64 x86_64 x86_64 GNU/Linux
> Upon installing Qgis it was offered the Qgis 3.2.0:
> $ dpkg -l qgis
> Desired=Unknown/Install/Remove/Purge/Hold
> | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
> |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
> ||/ Nome Versão Arquitectura Descrição
> ii qgis 1:3.2.0+28bi amd64 Geographic Information
> System (GI
> Until the upgrade I was using the last inception Qgis 2.18 in the
> Qgis stable repository:
> $ cat /etc/apt/sources.list.d/qgis-stable.list
> # http://www.qgis.org/en/site/forusers/alldownloads.html#ubuntu
> deb http://qgis.org/debian bionic main
> # deb-src http://qgis.org/debian trusty main
> # nightly binaries.
> # deb http://qgis.org/debian-nightly xenial main
> I am still finding my way on this new version.
> I have installed the DigitizingTools plugin from the oficial
> repository. On start os Qgis the issues the mesage:
> WARNING Plugin DigitizingTools : The plugin will be disabled
> because it crashed QGIS during last startup. Please report an issue and
> re-enable the plugin when the problem has been solved.
> If I try to activate it in the Plugin Manager I got this message at
> the terminal:
> QGIS died on signal 11Could not attach to process. If your uid matches
> the uid of the target process, check the setting
> of /proc/sys/kernel/yama/ptrace_scope, or try again as the root user.
> For more details, see /etc/sysctl.d/10-ptrace.conf ptrace: Operation
> not permitted. No thread selected
> No stack.
> gdb returned 0
> Aborted
> Is there any procedure I should use to help detect what the problem
> is?
It's a bug in that plugin -- you'll need to file it with the plugin's
author and try to get their attention.
Nyall
