[Qgis-user] QGIS 2.18 vs. QGIS 3
Patrick Dunford
enzedrailmaps at gmail.com
Thu Mar 1 03:32:45 PST 2018
2.18 can read 3's project files well but stuff like styles may not be
interpreted.
On 01/03/18 22:37, Andreas Neumann wrote:
> Hi Strumbi,
> They can be installed and run in parallel. They have independent settings.
> The only restriction is: once you have saved a project in QGIS 3,
> there may be no way back to 2.18.
> The other thing to watch out is plugins or Python code: plugins and
> Python code from QGIS 2.x don't run in QGIS 3.x. They have to be
> revised because of the change from Python 2 to Python 3 and qt4 to
> qt5. In addition, the QGIS API changed considerably. Theoretically, a
> plugin can be written to work in both QGIS 2 and QGIS 3, but in
> practice, such plugins don't exist very often.
> Greetings,
> Andreas
> On 01.03.2018 10:22, Velizar Strumberger wrote:
>> Hello
>> I apologize if this question has been asked already. Should I
>> uninstall QGIS 2.18 before I install QGIS 3.
>> Thank you
>> Strumbi
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180302/c55b1602/attachment.html>
