[Qgis-user] Mac OS X Install Notes
Adam Dershowitz dersh at alum.mit.edu
Thu Mar 1 10:13:39 PST 2018
I believe that SourceForge is currently having some serious problems, and that you are trying to download some files from there.  I have been seeing that today for a completely different port.
--Adam
> On Mar 1, 2018, at 10:58 AM, Jesús Lopez <jesusl.temez at gmail.com> wrote:
> Thanks for your notes John.
> When I try to build QGIS 3 with macports I get the following error:
> Verifying checksums for py36-pyqt5
> Error: Checksum (rmd160) mismatch for PyQt5_gpl-5.10.tar.gz
> Error: Checksum (sha256) mismatch for PyQt5_gpl-5.10.tar.gz
> The non-matching file appears to be HTML. See this page for possible reasons
> for the checksum mismatch:
> <https://trac.macports.org/wiki/MisbehavingServers <https://trac.macports.org/wiki/MisbehavingServers>>
> The file has been moved to: /opt/local/var/macports/distfiles/py-pyqt5/PyQt5_gpl-5.10.tar.gz.html
> Error: Failed to checksum py36-pyqt5: Unable to verify file checksums
> Error: See /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_macports_release_tarballs_ports_python_py-pyqt5/py36-pyqt5/main.log for details.
> Error: Follow https://guide.macports.org/#project.tickets <https://guide.macports.org/#project.tickets> to report a bug.
> Error: Processing of port qgis3 failed
> And install stops. Any idea on what’s the problem? Thanks!
> Jesus
>> El 28 feb 2018, a las 21:05, John Harrop <jcharrop at gmail.com <mailto:jcharrop at gmail.com>> escribió:
>> Having spent available spare time for the last couple of weeks trying to build QGIS 3 beta on a Mac - I’m happy to report I saw the light yesterday and it all came together.
>> The executive summary (assuming you have MapPorts installed):  sudo post install qgis3
>> Credit to several useful hints from various people here.  I must confess that having searched various places on the web I found several discussions about installing the various dependancies needed for QGIS, tweaking cmake files to get around problems etc and spent my time working though that - unsuccessfully.  Then yesterday, before starting to do dependancy installs, configure and build on a clean machine I have I did one last search for useful blogs and found the MapPorts qgis3 which I had missed previously.  It took a while to go through its paces, as expected, but it built just fine on my MacBook Pro.
>> Since finding beta testers is currently a priority is might be worth a note on the QGIS web page that this is available for Mac users.
>> Big thank you for the guys who did the work to get the MacPorts version working so well!
>> John Harrop, PGeo, FGS
>> Senior Project Geologist
>> Coast Mountain Geological Ltd
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180301/79dad70f/attachment.html>
