[Qgis-user] Mac OS X Install Notes
John Harrop jcharrop at gmail.com
Thu Mar 1 10:37:51 PST 2018
I had that problem (for the same package) during the “clean machine” build.  Try to clean the problem package out of your system and then install it again.  The worked for me:
(you only need sudo the first time probably, but I leave it in just to be safe.
sudo port clean py36-pyqt5
sudo port install py36-pyqt5
sudo port install qgis3
Hope that helps.
John Harrop, PGeo, FGS
Senior Project Geologist
Coast Mountain Geological Ltd
PO Box 62
Suite 488 - 625 Howe St
Vancouver, BC   V6C 2T6
Canada
jharrop at coastmountaingeo.com
+1 604 681-0209 office
+1 604 715-0987 cell
+353 83 469-1116 Ireland
j.harrop Skype
> On Mar 1, 2018, at 7:58 AM, Jesús Lopez <jesusl.temez at gmail.com> wrote:
> Thanks for your notes John.
> When I try to build QGIS 3 with macports I get the following error:
> Verifying checksums for py36-pyqt5
> Error: Checksum (rmd160) mismatch for PyQt5_gpl-5.10.tar.gz
> Error: Checksum (sha256) mismatch for PyQt5_gpl-5.10.tar.gz
> The non-matching file appears to be HTML. See this page for possible reasons
> for the checksum mismatch:
> <https://trac.macports.org/wiki/MisbehavingServers <https://trac.macports.org/wiki/MisbehavingServers>>
> The file has been moved to: /opt/local/var/macports/distfiles/py-pyqt5/PyQt5_gpl-5.10.tar.gz.html
> Error: Failed to checksum py36-pyqt5: Unable to verify file checksums
> Error: See /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_macports_release_tarballs_ports_python_py-pyqt5/py36-pyqt5/main.log for details.
> Error: Follow https://guide.macports.org/#project.tickets <https://guide.macports.org/#project.tickets> to report a bug.
> Error: Processing of port qgis3 failed
> And install stops. Any idea on what’s the problem? Thanks!
> Jesus
>> El 28 feb 2018, a las 21:05, John Harrop <jcharrop at gmail.com <mailto:jcharrop at gmail.com>> escribió:
>> Having spent available spare time for the last couple of weeks trying to build QGIS 3 beta on a Mac - I’m happy to report I saw the light yesterday and it all came together.
>> The executive summary (assuming you have MapPorts installed):  sudo post install qgis3
>> Credit to several useful hints from various people here.  I must confess that having searched various places on the web I found several discussions about installing the various dependancies needed for QGIS, tweaking cmake files to get around problems etc and spent my time working though that - unsuccessfully.  Then yesterday, before starting to do dependancy installs, configure and build on a clean machine I have I did one last search for useful blogs and found the MapPorts qgis3 which I had missed previously.  It took a while to go through its paces, as expected, but it built just fine on my MacBook Pro.
>> Since finding beta testers is currently a priority is might be worth a note on the QGIS web page that this is available for Mac users.
>> Big thank you for the guys who did the work to get the MacPorts version working so well!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180301/79ac9e68/attachment.html>
