[Qgis-user] QGIS Crashes on attempts to edit attribute table
Frank Sokolic sokolic at worldonline.co.za
Fri Mar 2 22:42:31 PST 2018
Hi Will,
You could try opening a terminal (Ctrl+Alt+T) and running QGIS by typing
in 'QGIS'. Then try editing a table and when/if QGIS crashes see if any
meaningful message is shown in the terminal. This might provide a clue
as to what's causing the crash.
Frank.
On 02/03/2018 19:28, William Roper wrote:
> OK good tips to rule out local issues.
> I will have to make a vm, so will try that over the weekend.
> Many thanks.
> Will
> On 2 Mar 2018 16:04, "Alessandro Pasotti" <apasotti at gmail.com
> <mailto:apasotti at gmail.com>> wrote:
>     Hi,
>     if you want to file a bug report, please make sure you attach a
>     small sample project and data and explain step-by-step how to
>     reproduce the issue.
>     https://issues.qgis.org/issues
>     On Fri, Mar 2, 2018 at 4:10 PM, William Roper
>     <roper.william at gmail.com <mailto:roper.william at gmail.com>> wrote:
>         Hello,
>         I'm using QGIS3 on Ubuntu16.04 and I've been experiencing
>         frustrations with it crashing if I attempt to edit attribute.
>         It will open the attribute table, but won't let me make edits.
>         I would like to submit a bug report but don't really know how
>         much detail to offer, so some guidance on that would be useful
>         - unless someone happens to know a solution!
>         Regards
>         Will
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>         Unsubscribe:
>     Alessandro Pasotti
>     w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180303/fa10b361/attachment.html>
