[Qgis-user] QGIS Crashes on attempts to edit attribute table
William Roper roper.william at gmail.com
Sat Mar 3 04:30:44 PST 2018
Just an update on this.
Couldn't reproduce in a VM. reinstalled QGIS and no joy, so last ditch
before OS reinstall was to delete all the *QGIS* directories in my home
directory that contained local config. That seemed to sort it. Not sure
what it was, but got a working install now. Thanks for the pointers. Loving
QGIS3 :D
Will
On 3 March 2018 at 06:42, Frank Sokolic <sokolic at worldonline.co.za> wrote:
> Hi Will,
> You could try opening a terminal (Ctrl+Alt+T) and running QGIS by typing
> in 'QGIS'. Then try editing a table and when/if QGIS crashes see if any
> meaningful message is shown in the terminal. This might provide a clue as
> to what's causing the crash.
> Frank.
> On 02/03/2018 19:28, William Roper wrote:
> OK good tips to rule out local issues.
> I will have to make a vm, so will try that over the weekend.
> Many thanks.
> Will
> On 2 Mar 2018 16:04, "Alessandro Pasotti" <apasotti at gmail.com> wrote:
>> Hi,
>> if you want to file a bug report, please make sure you attach a small
>> sample project and data and explain step-by-step how to reproduce the issue.
>> https://issues.qgis.org/issues
>> On Fri, Mar 2, 2018 at 4:10 PM, William Roper <roper.william at gmail.com>
>> wrote:
>>> Hello,
>>> I'm using QGIS3 on Ubuntu16.04 and I've been experiencing frustrations
>>> with it crashing if I attempt to edit attribute. It will open the attribute
>>> table, but won't let me make edits. I would like to submit a bug report but
>>> don't really know how much detail to offer, so some guidance on that would
>>> be useful - unless someone happens to know a solution!
>>> Regards
>>> Will
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alessandro Pasotti
>> w3:   www.itopen.it
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180303/06a11545/attachment.html>
