[Qgis-user] Mac OS X MacPorts installation for QGIS 3 beta
Jesús Lopez jesusl.temez at gmail.com
Sun Mar 4 03:25:08 PST 2018
Thanks for your effort John.
Following your instructions (and after sourceforge returned to the activity) I have been able to install Qgis without major problems in a MacPro with 10.11.6 system.
The version installed is 2.99.20180124. Should not it be 3.0? Despiste this and once installed, it starts without problems. At the time of using it is when the problems begin. As I try to change anything in the properties of any layer, Qgis hangs and I have to force quit. This behavior makes Qgis practically unusable. Any idea what can happen? The installation process did not give any error.
Thank you all.
Jesus
> El 02 mar 2018, a las 22:37, John Harrop <jcharrop at gmail.com <mailto:jcharrop at gmail.com>> escribió:
> The following notes are based on an install on a clean iMac (the disk has just been replaced) running High Sierra (10.13.3).  The installation was done using MacPorts and their qgis3 port.  When I describe more than one install method, the first one is the one I used.  These is no reason to be a programmer to run through this installation procedure.  Some will need to be done from the command line, so you should locate Terminal if you don’t already have it on your Dock.  You should find it in the Other directory in your Applications.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180304/4c21528f/attachment.html>
