[Qgis-user] Ubuntu xenial qgis3 crashes on startup
Ian Turton ijturton at gmail.com
Mon Mar 5 01:18:48 PST 2018
Resending with out the full error log included as its too big for the list.
Ian
On 4 March 2018 at 11:50, Ian Turton <ijturton at gmail.com> wrote:
> On my Ubunut box (Linux astun-desktop 4.13.0-36-generic #40~16.04.1-Ubuntu
> SMP Fri Feb 16 23:25:58 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux) when I
> install QGIS from ubuntugis I get a core dump when trying to run it. I
> previously had 2.99 running with no issues. While my laptop with the same
> OS went from 2.18.x to 3.0 with out issue.
> when run as a normal user I get:
> QGIS died on signal 11Could not attach to process.  If your uid matches
> the uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Operation not permitted.
> No thread selected
> No stack.
> gdb returned 0
> [1]    28313 abort (core dumped)  qgis
> As root I get the slightly more helpful but much longer response see
> https://pastebin.com/nNvGB6Se
 it starts off with
QGIS died on signal 11[New LWP 28536]
[New LWP 28537]
[New LWP 28547]
[New LWP 28555]
[New LWP 28557]
[New LWP 28558]
[New LWP 28559]
[New LWP 28560]
[New LWP 28561]
[New LWP 28562]
[New LWP 28563]
[New LWP 28564]
[New LWP 28567]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007efe0224b0cb in __GI___waitpid (pid=28568, stat_loc=0x7fffd1857d2c,
options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
29    ../sysdeps/unix/sysv/linux/waitpid.c: No such file or directory.
[Current thread is 1 (Thread 0x7efde1df6300 (LWP 28533))]
#0  0x00007efe0224b0cb in __GI___waitpid (pid=28568,
stat_loc=0x7fffd1857d2c, options=0) at
        resultvar = 18446744073709551104
        sc_cancel_oldtype = 0
#1  0x000055c2c944acaa in ?? ()
No symbol table info available.
#2  <signal handler called>
No locals.
> Ian Turton
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180305/8db0d7b4/attachment.html>
