[Qgis-user] Pseudo Mercator(OSM) @ EPSG:4326 bug?
Idan Miara idan at miara.com
Mon Mar 5 04:22:56 PST 2018
It does, but the problem is when I set the project CRS to 4326, so the
tiles are projected from 3857 to 4326. The vector layer is not projected.
On 5 Mar 2018 13:23, "Andre Joost" <andre+joost at nurfuerspam.de> wrote:
Am 05.03.18 um 09:38 schrieb Idan Miara:
> I might have found a bug related to transformation of layer CRS from
> EPSG:3857
> (Pseudo Mercator) to EPSG:4325 (WGS84 Geo).
> I'm attaching a few images to demonstrate the issue.
> Steps to reproduce:
> I've load OSM in QGIS 2.18.16 (or 3.0,same results)
> via Tile Server (XYZ):
> https://a.tile.openstreetmap.org/{z}/{x}/{y}.png
> Then set the CRS to EPSG:4326 (WGS84 Geo)
> I've also loaded a global bounds vector layer (EPSG:4326)
Does the vector layer contain the north or south pole? EPSG:3857 does not
like that (it would be in infinity). The same might happen if you request
tiles beyond 85°N/S.
HTH,
Andre Joost
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180305/144e449f/attachment.html>
