[Qgis-user] Error 3D View QGIS 3.0 - *Crash ID*: 40e66737578440d0e4a40fa8545b665a86f88731
Stefan Giese
Stefan.Giese at wheregroup.com
Wed Mar 7 01:38:36 PST 2018
Hi Alejandro,
I had the same issue with the vienna example on my notebook but on my
desktop computer it works fine. I identified the graphic card as the
problem.
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Treffen Sie uns auf der
FOSSGIS Konferenz 2018
21.-24. März 2018 in Bonn
https://fossgis-konferenz.de/2018/
WhereGroup GmbH & Co. KG
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 07.03.2018 um 09:55 schrieb Alejandro Chamizo de Castro:
> Hello colleagues,
> I'm not sure which is the list in which the QGIS 3.0 bugs should be
> published, that's why I send it in this list, I'm sorry.
> I tried to visualize a 3D coverage of Vienna according to the
> following tutorial [1] , and I get the following error:
> h2. User Feedback
> h2. Report Details
> *Stack Trace*
> <pre>
> DrvGetLayerPaletteEntries :
> RegisterProcTableCallback :
> Qt3DRender::Render::Renderer::performDraw :
> Qt3DRender::Render::Renderer::executeCommandsSubmission :
> Qt3DRender::Render::Renderer::submitRenderViews :
> Qt3DRender::Render::Renderer::doRender :
> Qt3DRender::Render::Renderer::render :
> Qt3DRender::Render::NodeManagers::renderTargetManager :
> QThread::start :
> BaseThreadInitThunk :
> RtlUserThreadStart :
> </pre>
> *QGIS Info*
> QGIS Version: 3.0.0-Girona
> QGIS code revision: commit:001c80b0c3
> Compiled against Qt: 5.9.2
> Running against Qt: 5.9.2
> Compiled against GDAL: 2.2.3
> Running against GDAL: 2.2.3
> *System Info*
> CPU Type: x86_64
> Kernel Type: winnt
> Kernel Version: 10.0.16299
> Thanks a lot
> [1]
> https://www.labgis.uerj.br/noticias/introducao-a-visualizacao-3d-do-qgis-com-dados-de-construcao-vienense&utm_source=maladireta
> Coordinador Técnico SIG
> GESCUENCAS II
> www.fotex.es <http://www.fotex.es/>
> Móvil: 653 681 823
> Fijo: 924 207 328
> Fax: 924 234 389
> Este mensaje y sus archivos son confidenciales. No esta permitida su
> reproducción o distribución sin la autorización expresa de FOTEX SL.
> Si usted no es el destinatario previsto, queda desautorizado cualquier
> uso, acceso o copia de este mensaje. Si usted ha recibido este mensaje
> por error, por favor bórrelo e infórmenos por esta misma vía.
> De acuerdo con la LSSICE y la LOPD, le comunicamos que sus datos
> personales y dirección de correo electrónico forman parte de un
> fichero automatizado, cuyo responsable es FOTEX SL, siendo la
> finalidad del fichero el envío de información sobre nuestros
> servicios. Si lo desea puede ejercer los derechos de oposición,
> acceso, rectificación y cancelación de sus datos enviando un mensaje
> de correo electrónico a informatica at fotex.es
> <mailto:informatica at fotex.es> indicando en el asunto el derecho que
> desea ejercitar.
> Gracias por su colaboración.
> Por favor, piensa en el medio ambiente antes de imprimir este correo.
> <https://mailtrack.io/> Enviado con Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality&>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180307/8f5201df/attachment.html>
