[Qgis-user] Error 3D View QGIS 3.0 - *Crash ID*: 40e66737578440d0e4a40fa8545b665a86f88731
Andreas Neumann a.neumann at carto.net
Wed Mar 7 01:43:56 PST 2018
Yes - I also heard that certain graphic cards have issues with QGIS 3D,
unfortunately. For these issues, the only solution is to switch to a
different machine with a different graphics card. Lets hope that future
qt versions will fix this issue.
As to your question how to report issues: please do not send them to the
users lists, unless you want to first discuss an issue. Otherwise, just
open a new issue at https://issues.qgis.org/
Before reporting issues, please first read
https://www.qgis.org/en/site/getinvolved/development/bugreporting.html -
we receive a lot of issue reports that lack information or which are
duplicates of already existing issues, or which we are simply not able
to reproduce. Try to narrow down the problem and please provide some
sample data that allows us to reproduce the issue.
In your particular case, if it works fine on a different machine with a
different graphics card, then there is nothing we can do, unfortunately.
In such a case, please don't report the issue as we can't solve it
without fixes in the upstream library (qt5-qt3d).
Greetings,
Andreas
On 07.03.2018 10:38, Stefan Giese wrote:
> Hi Alejandro,
> I had the same issue with the vienna example on my notebook but on my
> desktop computer it works fine. I identified the graphic card as the
> problem.
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Treffen Sie uns auf der
> FOSSGIS Konferenz 2018
> 21.-24. März 2018 in Bonn
> https://fossgis-konferenz.de/2018/
> WhereGroup GmbH & Co. KG
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Am 07.03.2018 um 09:55 schrieb Alejandro Chamizo de Castro:
>> Hello colleagues,
>> I'm not sure which is the list in which the QGIS 3.0 bugs should be
>> published, that's why I send it in this list, I'm sorry.
>> I tried to visualize a 3D coverage of Vienna according to the
>> following tutorial [1] , and I get the following error:
>> h2. User Feedback
>> h2. Report Details
>> *Stack Trace*
>> <pre>
>> DrvGetLayerPaletteEntries :
>> RegisterProcTableCallback :
>> Qt3DRender::Render::Renderer::performDraw :
>> Qt3DRender::Render::Renderer::executeCommandsSubmission :
>> Qt3DRender::Render::Renderer::submitRenderViews :
>> Qt3DRender::Render::Renderer::doRender :
>> Qt3DRender::Render::Renderer::render :
>> Qt3DRender::Render::NodeManagers::renderTargetManager :
>> QThread::start :
>> BaseThreadInitThunk :
>> RtlUserThreadStart :
>> </pre>
>> *QGIS Info*
>> QGIS Version: 3.0.0-Girona
>> QGIS code revision: commit:001c80b0c3
>> Compiled against Qt: 5.9.2
>> Running against Qt: 5.9.2
>> Compiled against GDAL: 2.2.3
>> Running against GDAL: 2.2.3
>> *System Info*
>> CPU Type: x86_64
>> Kernel Type: winnt
>> Kernel Version: 10.0.16299
>> Thanks a lot
>> [1]
>> https://www.labgis.uerj.br/noticias/introducao-a-visualizacao-3d-do-qgis-com-dados-de-construcao-vienense&utm_source=maladireta
>> Coordinador Técnico SIG
>> GESCUENCAS II
>> www.fotex.es <http://www.fotex.es/>
>> Móvil: 653 681 823
>> Fijo: 924 207 328
>> Fax: 924 234 389
>> Este mensaje y sus archivos son confidenciales. No esta permitida su
>> reproducción o distribución sin la autorización expresa de FOTEX SL.
>> Si usted no es el destinatario previsto, queda desautorizado
>> cualquier uso, acceso o copia de este mensaje. Si usted ha recibido
>> este mensaje por error, por favor bórrelo e infórmenos por esta misma
>> vía.
>> De acuerdo con la LSSICE y la LOPD, le comunicamos que sus datos
>> personales y dirección de correo electrónico forman parte de un
>> fichero automatizado, cuyo responsable es FOTEX SL, siendo la
>> finalidad del fichero el envío de información sobre nuestros
>> servicios. Si lo desea puede ejercer los derechos de oposición,
>> acceso, rectificación y cancelación de sus datos enviando un mensaje
>> de correo electrónico a informatica at fotex.es
>> <mailto:informatica at fotex.es> indicando en el asunto el derecho que
>> desea ejercitar.
>> Gracias por su colaboración.
>> Por favor, piensa en el medio ambiente antes de imprimir este correo.
>>>> <https://mailtrack.io/> Enviado con Mailtrack
>> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality&>
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180307/580bb9fa/attachment.html>
