[Qgis-user] Missing plugins on CentOS 7 Linux version of QGIS 2.14.9
Patrick Dunford enzedrailmaps at gmail.com
Sat Mar 10 19:34:52 PST 2018
If your repository does not have 2.18 you may have the option of
building from source, as the dependencies are probably nearly the same.
On 11/03/18 01:53, prospector16 wrote:
> Thanks everyone.
> I just went for the version out of the Linux EPEL Repository.
> If it does not support 2.18 yet then I cannot easily run 2.18
> unless someone can point me at a better source for it.
> I installed the python support and now see all the plugins.  When I try to
> install the OpenLayers plugin it says "Cannot import QtWebKit" and tells me
> I should uninstall.
> The other plugin works but does not seem to have very useful base layers.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
