[Qgis-user] Atlas Map Book Design
Andreas Neumann a.neumann at carto.net
Sun Mar 18 10:01:48 PDT 2018
You can easily install QGIS 3 in parallel with QGIS 2.18. They have
separate settings, plugins, etc. - no need to fear an upgrade.
They only thing you probably can't do is opening a 3.0 project in 2.18 -
esp. if you use new features of version 3 that haven't been available in
2.18.
The sad stories about components not working - are you refering to
plugins? This is a well-known issue that needs to be addressed - and
will be addressed - just needs some time. It was long-ago (and
repeatedly) announced that QGIS 2 plugins aren't compatible with QGIS 3.
Greetings,
Andreas
On 18.03.2018 17:58, Springfield Harrison wrote:
> Thank you, but no I haven't. I'm very leery of upgrading, especially
> when I read all the sad stories how about components not working and
> installations going sideways.
> If this upgrade to Windows 7 is Bulletproof, maybe I'll give it a try.
> I have always been confused by the plethora of installation options
> for this software.
> Does the new reporting mode still include the atlas / multi-page printing?
> Cheers . . . . .   Spring
> Samsung Tab 4
> On Mar 18, 2018 9:49 AM, "Andreas Neumann" <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi Harrison,
>     Have you tried the new reporting mode in QGIS 3? It is pretty new
>     - so maybe it doesn't fit all requirements yet - but it allows you
>     to have section titles, footers and headers, etc. Maybe worth a try?
>     Greetings,
>     Andreas
>     On 18.03.2018 15:38, Springfield Harrison wrote:
>         Hello All,
>         I am able to create map books using the Atlas feature but do
>         not need the title block (text box) on every page.
>         Is there a method to control the content of each page (as in
>         Manifold GIS?)?
>         Thanks very much . . . .
>         Cheers . . . . . Springfield Harrison
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>         Unsubscribe:
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180318/1961350b/attachment.html>
