[Qgis-user] Grass not found
jehdukeegr at gmail.com
Mon Mar 19 12:15:31 PDT 2018
I'm a new Qgis user. Here are the details:
Qgis version 3.0.0 (Downloaded 3/17)
MAC OS 10.12.6 (Sierra)
I'm trying to use Grass to do some shortest distance network calculations
and I receive the following error messages:
/var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_8f76fdc70e874abb92d2ebbbef92c2d3/grassdata/temp_location/PERMANENT:
/Applications/QGIS: No such file or directory
and
The following layers were not correctly generated.
/var/folders/d3/q41sw4cj5_s479lpjf1z3hwc0000gn/T/processing_8f76fdc70e874abb92d2ebbbef92c2d3/d24dd229b47946bb8d89c4b98af4e5fe/output.shp
After searching around I've tried updating the directories in GRASS options
as suggested here:
https://gis.stackexchange.com/questions/219808/finding-grass-module-after-upgrading-qgis-mac
Still no dice. Now I also get the following error when starting Qgis:
GRASS init error: GRASS was not found in '/Applications/QGIS
3.app/Contents/MacOS/grass7' (GISBASE), provider and plugin will not work.
Any ideas?
Thanks in advance. Otherwise, this is way better than my old ArcGIS
packages.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180319/f176c8d3/attachment.html>
