[Qgis-user] Question on Georeferencer
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Mon Mar 19 15:56:18 PDT 2018
Make sure your input file and the project have the proper CRS.  Do not use On the fly project projection.  That will help with the trouble shooting.  What version of QGIS are you working with?
Nicolas
> Le 19 mars 2018 à 15:15, Thomas WTS <thomas.steven at w-ts.com> a écrit :
> Hi,
> I’m trying to georeference a map using the georeferencer. The map is in the USA, which has negative latitude values. When I georeference, the lat values come out wrong as they convert the negative values into positive. Any tips on how to use the georeferencer so as to avoid this problem?
> My settings at the moment are as below.
> <image001.png>
> Many thanks,
> Thomas
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180319/78130d82/attachment.html>
