[Qgis-user] problem with RT MapServer Exporter
Salvatore Mellino (Prisma srl) salvatore.mellino at prismambiente.it
Tue Mar 20 02:09:17 PDT 2018
Hello,
thank you for your reply. I never used qgis server and if I really
apreciate if you breafly describe the method to export a map file for
pmapper.
Any other suggestion to install python-mapscript?
Salvatore
Il 19/03/2018 20:18, Paolo Cavallini ha scritto:
> As said, you miss python-mapscript.
> However, we suggest you to use QGIS server instead.
> All the best.
> Il 19 marzo 2018 13:52:24 GMT-04:00, "Salvatore Mellino (Prisma srl)"
> <salvatore.mellino at prismambiente.it> ha scritto:
>     Hello,
>     I am trying to use the RT MapServer Exporter with qgis 2.18.17
>     installed on windows10 but I recived the follow error message:
>     2018-03-19T18:37:46 1 Traceback (most recent call last):
>     File
>     "C:/Users/Salvatore/.qgis2/python/plugins\rt_mapserver_exporter\plugin.py",
>     line 65, in run
>     from .mapfileexportdlg import MapfileExportDlg
>     File
>     "C:/PROGRA~1/QGIS2~1.18/apps/qgis-ltr/./python\qgis\utils.py",
>     line 607, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>     File
>     "C:/Users/Salvatore/.qgis2/python/plugins\rt_mapserver_exporter\mapfileexportdlg.py",
>     line 31, in <module>
>     import MapfileExporter
>     File
>     File
>     "C:/Users/Salvatore/.qgis2/python/plugins\rt_mapserver_exporter\MapfileExporter.py",
>     line 9, in <module>
>     from utils import *
>     File
>     File
>     "C:/Users/Salvatore/.qgis2/python/plugins\rt_mapserver_exporter\utils.py",
>     line 1, in <module>
>     import mapscript
>     File
>     ImportError: No module named mapscript
>     I tried to install python mapscript by osgeo4w-setup-x86_64.exe
>     (advanced install) but this does not resolve the problem.
>     Any suggestion?
>     Thank you for your help.
>     Salvatore
> Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180320/2c40b3ad/attachment.html>
