[Qgis-user] Newbie coding question
jehdukeegr at gmail.com jehdukeegr at gmail.com
Tue Mar 20 14:29:53 PDT 2018
So, I'm trying to do bunch of shortest distance calculations using two
point layers and a line layer.  Reading the forums etc. I gather there
isn't a GUI solution for this.  As a result, I'm trying to adapt the code
here:
https://gis.stackexchange.com/questions/171896/how-to-calculate-shortest-path-from-points-in-one-layer-to-points-in-another-lay
I'm using Qgis version 3.0.2.
However, when I run my script I receive the error:
"ImportError: cannot import name 'VectorWriter'"
Which I gather is coming from the import command:
"from processing.tools.vector import VectorWriter"
I'm guessing this is because this module doesn't exist or is called
something different since the script I am copying was written?  Any
suggestions?
Thanks in advance!
-J
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20180320/408abbce/attachment.html>
